Extension Attribute based on a file being modified more/less than N minutes/days ago
  • August 6, 2015
  • 16 views
donmontalvo
Forum|alt.badge.img+36
Sorry, its late and I'm hungry...
# If Pizza is less than 30 minutes old, return "YumYum".
# If Pizza is more than 30 minutes old, return "EwwYuk".
# Can use -mmin for minutes, or -mday for days.
Pizza=`find /path/to/pizza -mmin -30 -print`
YumYum="/path/to/pizza"
EwwYuk=""
if [ "$Pizza" == "$YumYum" ];
then
    echo "<result>YumYum</result>"
    echo "<result>EwwYuk</result>"
<burp>
HTH,
Don
dpertschi
Forum|alt.badge.img+19
  • August 6, 2015
@donmontalvo are you having side effects from wild fire smoke inhalation?
donmontalvo
  • August 7, 2015
Haha...I had to sanitize the script, so pizza was the first thing that came to mind. :)
donmontalvo
  • August 17, 2015
Shorter:
if [ `find /path/to/pizza -mmin -30 -print` ]; then
