Extension Attribute for USB Scanner
  • October 15, 2019
  • 17 views
I'm attempting to create an extension attribute that will echo the following command.
sudo system_profiler SPPrintersDataType | grep 'Perfection|Expression'
What I have so far in the EA is
echo "<result>system_profiler SPPrintersDataType | grep 'Perfection|Expression</result>"
Any suggestions are appreciated.
1 reply
  • October 15, 2019
Looks like you are missing the ' at the end of Perfection|Expression
echo "<result>system_profiler SPPrintersDataType | grep 'Perfection|Expression'</result>"
