Posted on
03-03-2017
02:16 PM
- last edited on
03-04-2025
05:27 AM
by
kh-richa_mig
Hey All,
Wondering if anyone out there has:
A) installed or worked with Digital Guardian DLP software for Mac?
B) successfully created an extension attribute that reports the agent version installed?
C) mastered the rare art form of text manipulation in the command line and can help me regardless of the software I'm reporting on?
DG's command line binary, "dgctl" has an easy way to report on the currently installed version by typing the following into a Terminal window: "dgagent/dgctl --version" which outputs the following (excessively verbose in my opinion) info:
2017-03-03 16:55:14.968 dgctl[19465:70794] DGAgent for Mac OS X version 7.1.4.0004
2017-03-03 16:55:14.969 dgctl[19465:70794] OK
I've tried piping into tools (and combinations thereof) using sed, grep, awk, cut etc. and no matter what I try, I just get a blank response and no output. I'm looking to cut out everything except the "7.1.4.0004" ideally, but getting frustrated that I can't seem to modify the text at all.
Even by removing any pipes into txt manipulation and just attempting to return the two line result with an echo returns nothing, i.e.
if [ -d /dgagent ] ; then
dgVersion=$( /dgagent/dgctl --version )
echo "DG version is $dgVersion"
echo "<result>Not Installed</result>"
Before you ask, no, there does not appear to be any plist, log or other static/clear text item installed that I could use instead to report on the version number. Seems like you must get the information by running this command.
Any expert scripting/EA help out there would be very much appreciated! Thank you!
Solved! Go to Solution.
Posted on 03-06-2017 01:00 PM
Try this:
dgagent/dgctl --version 2>&1 | head -n1 | awk '{print $10}'
Posted on 03-03-2017 02:20 PM
Seems like you should be able to do:
dgagent/dgctl --version | head -n1 | awk '{print $10}'
Assuming the result is always output that way.
Posted on 03-06-2017 12:57 PM
Thank you @iJake for the suggestion! Unfortunately no luck and same results... It is almost as if Verdasys (Digital Guardian developer) follows some kind of non-standard output method that is unable to be manipulated and is not clear text. I'll keep trying different stuff and see what the vendor says. Thanks again.
Try this:
Posted on 03-06-2017 01:11 PM
Yes, that did it! Thanks, should have thought of that! Appreciate the help!
Posted on 03-06-2017 01:14 PM
Glad to help!
Posted on 03-14-2018 02:59 PM
If your interested I can share a nice bundle of DG related EAs I have created to assist in its management and deployment. I am in the process of updating and posting my github, so you can either wait or reply this post and I will provide via other means.
-Frank J
Posted on 03-14-2018 04:07 PM
@ShadowGT Your DG-related EAs would be appreciated.
-- Mike
Posted on 03-15-2018 08:40 AM
I will be posting more as it scrub and get clearance, but here are the basic ones. I hope it helps:
Posted on 03-15-2018 09:20 AM
Just saw this, here's the script I have to check the version after working with DG a few years ago.
/dgagent/dgctl --version 2>&1 | grep Mac | awk '{ print $NF}'
which I threw into an EA
DGA=$(/dgagent/dgctl --version 2>&1 | grep Mac | awk '{ print $NF}')
if [[ -z $DGA ]] ; then
echo "<result>$DGA</result>"
My only suggestion is using
awk '{ print $NF}'`
over
awk '{print $10}'
In the off chance that that response isn't the 10th string in the future, where as $NF prints the last string. As a side note, I have the unique pleasure distinction luck pain of being the first Mac DG deployment (so they say). It was really bad early going, when they'd just throw code to us untested for us to "work" with.
