extract string with backslashes
Sorry for a noob question but I have a hard time to extract a string from another string and I'm sure one of you geeks has a simple answer for this.
I have a string like "domainnameusername" that I extract from a plist using defaults read. I got the domainname with cut -d '' -f1 but I can't get the username. I tried cut -d '' -f2 and cut -d '' -f3 and cut -d '' -f2 and I always end with an empty string. I'm sure it's all about escaping but I don't know enough yet to figure this out.
Thanks,
Dirk
Best answer by tron_jones
string='domainnameusername'
username=echo $string | cut -d '' -f3
echo $username
  • 94 replies
  • March 13, 2014
echo $username
  • 50 replies
  • March 13, 2014
I knew it was easy for you.
I tired to do everything in one line and that didn't work. Extracting the full string first to a temp variable and then using echo works perfectly. Lesson learned. Thanks!
  • 529 replies
  • March 20, 2014
You can get echo to do all the work for you:
string='domainname\\username'
username=`echo ${string##*\\}`
domainname=`echo ${string%%\\*}`
echo $username
echo $domainname
Cookie policy
Cookie settings
