Hi Everyone,
I am again writing about a failed attempt and packaging a Final Cut Studio 3 using the latest composer. I created this from an iMac which is identical to the ones in the lab. I then took a basic install of only the OS with all the updates applied. I used our volume license to install Final Cut on the iMac. This after creating the snapshot and following up after installed and updated for Pro Apps. So I built a .pkg installer and moved it to the Imaging Admin app and tested. Most of the apps error out on trying to open. Some open with errors and 1 doesn't have a problem.
Any thoughts on how to proceed? I know the process is hours in the making so to keep trying and trying and having it failed is really a problem. We may have to resort to creating a whole separate image with it already installed as a Base image so to speak.
I appreciate all of your time in trying to help me figure this one out.
Mick
Michael D. Conners, APP
Apple Project Leader
3550 Anderson Street
Madison, WI 53704
Phone: 608-246-6360
Fax: 608-246-6329
Work E-Mail: mconners at matcmadison.edu
www.realworldsmart.com
