Gathering User info for Mobile devices
ajamfadmin1810
Contributor
Hello
I am setting up our Jamf environment for managing phones but I noticed that it does not pass user info to JAMF after its assigned. Is there anyway to have Jamf ask for credentials or recon some sort of credentials to Jamf? we use OneLogin with jamf Connect on our laptops
1 ACCEPTED SOLUTION
jcarr
Authenticated enrollment would do this for you.  Assuming your Jamf is connected to LDAP (or a cloud identity provider), the user could be required to log in when you hand out the device.  iOS/iPadOS 13 and later can also use a custom enrollment screen with your logo, colors and custom text (e.g. "By enrolling this device you agree to the terms of the Acceptable Use Policy.").
1 REPLY 1
jcarr
