GoodNotes for Business for MacBook
  • August 24, 2023
  • 7 replies
  • 71 views
Hey.
Im trying to upgrade GoodNotes for Institutions into GoodNotes for Business.
There is only an instruction how to install a license key for iPad/iPhone (https://support.goodnotes.com/hc/en-us/articles/7568710302607-Installing-Goodnotes-for-Business-Enterprise-via-Jamf-Pro?source=search&auth_token=eyJhbGciOiJIUzI1NiJ9.eyJhY2NvdW50X2lkIjoyNTM0NzUsInVzZXJfaWQiOjc3MDkxMDA4MjcwMjMsInRpY2tldF9pZCI6MjMzMjk5LCJjaGFubmVsX2lkIjo2MywidHlwZSI6IlNFQVJDSCIsImV4cCI6MTY5NTIyMjU1OX0.MN6d_0tdipaCu0_cJb_fbyPYt1kHRPpY9l69iLvegXo).
Does someone know how I can install a license on MacBook via JamfPro?
Best answer by justin_beek
Were you able to deploy the licenses? I follow the instructions based on the Goodnotes support link above but the app doesn't recognize that a license has been deployed. Scope is set correctly and installed based on the log. The same license key is valid works without problems for our organizations iPads. Not sure what I'm missing.
yes.
https://ibb.co/0nW8NLS
Our plist:
<plist version="1.0">
  <dict>
    <key>com.goodnotesapp.x.managed</key>
    <dict>
      <key>LicenseKey</key>
      <string>XXXXXX-XXXXXX-XXXXXX-XXXXXX-XXXXXX-V3</string>
    </dict>
  </dict>
</plist>
  • November 29, 2023
Same issue.
I am guessing setup App and use Composer?
  • August 8, 2024
  • September 25, 2024
yes.
Our plist:
  <dict>
    <dict>
    </dict>
  </dict>
</plist>
  • September 26, 2024
I've done the same thing but in Goodnotes on the Mac it still gives me these errors. In JAMF, it says that the profile has been pushed through. Any ideas?
  • September 27, 2024
FIXED: There was an extra colon in our application domain field. The solution above works well.
  • October 9, 2024
yes.
Our plist:
  <dict>
    <dict>
    </dict>
  </dict>
</plist>
It worked. Appreciate it!
