Guide: How To Configure Jamf Pro SMTP with M365
  • April 20, 2022
  • 46 replies
  • 1105 views
Overview:
I was really struggling to configure SMTP with M365. We have a distribution list that our Operations team are all apart of and wanted to receive email notifications from Jamf for a variety of reasons.
Our environment has MFA enabled and I was continuously fighting with both Jamf/Azure to figure out a workaround to the authentication errors I was seeing in the Jamf Server Logs.
It wasn't until after creating a service account without MFA applied it(account being authenticated in Jamf SMTP) and enabling "Send As" and "Send on behalf" in the distribution list by adding the service account to the delegates list that mail was delivered.
Lets look at a couple server logs I was experiencing first.
Server Log Error generated from an account with MFA enabled:
  • javax.mail.AuthenticationFailedException: Authentication unsuccessful, the request did not meet the criteria to be authenticated successfully. Contact your administrator.
With the error above I messed around in Azure quite a bit and got no where. I made exceptions with my user for MFA and I attempted trying to configure an "App Password" which doesn't seem to exist anymore? Or at least was not available within my users account settings for some reason.
Server log Error generated from authenticating with a service account created in M365 with no MFA enabled.
  • com.sun.mail.smtp.SMTPSendFailedException: SendAsDenied;
The "SendAsDenied" stuck out to me and I remembered in Exchange that you could configure an account to "Send As". It wasn't until after enabling the service account (account being authenticated in Jamf SMTP) to send as the distribution list that I was targeting mail was finally delivered.
Below is the configuration / solution which allowed for mail to be delivered successfully from Jamf Pro to our M365 Server using a service account without MFA.
Microsoft 365 Configuration:
Step 1: Navigate to admin.microsoft.com
Step 2: Users > Active Users > Add a User
  • Enter all required information. I added Exchange Admin as Administrator credentials to this service account.
  • Assign a license that will provide this service account a mailbox.
  • In the User settings > Mail > Mail Apps > verify that Authenticated SMTP is enabled.
Step 3: Navigate to Exchange Online Admin Center from M365 Admin Center.
Step 4: Navigate to Recipients > Groups > Distribution List and locate the Distribution List you want to target.
Step 5: Select the Distribution List > Settings > Manage Delegates > Edit Delegates  > Add a delegate > Add the service account you created and choose the “send on behalf” option. Save changes.
Jamf Pro Configuration:
Step 1: Sign into your Jamf Cloud Instance
Step 2: Select the Settings cog in the top right
Step 3: Navigate to System Settings > SMTP Server
Step 4: Enter the following information:
  • Server and port: smtp.office365.com | 587
  • Encryption: TLSv1.2
  • Connection Timeout: 15 [You can play around with this depending on what you want/need]
  • Sender Display Name: [Up to you]
  • Sender Email Address: Enter the mailing address you want mail to be sent from. I sent mine from a distribution group.
  • Requires Authentication: Enter the credentials of the service account you’ve created in M365.
Step 5:
Save and Test. At this point I received an email.
Note: This is how I accomplished this, it may not work for your environment. If you think I skipped a step or didn't explain something clearly please let me know and I'll take a look.
RaxiaDK
  • April 27, 2022
Thank you for your guide, I keep getting: javax.mail.AuthenticationFailedException: 535 5.7.139 Authentication unsuccessful, basic authentication is disabled. [AS8PR07CA0033.eurprd07.prod.outlook.com]
This not working for me: Disable Basic authentication in Exchange Online | Microsoft Docs
  • June 4, 2022
Foe Me Its work First time only Not sure why But its working
"A test message was successfully sent."
https://docs.microsoft.com/en-us/exchange/clients-and-mobile-in-exchange-online/authenticated-client-smtp-submission
RaxiaDK
  • June 24, 2022
it was a time issue, it work for me now
scottb
  • July 11, 2022
Can anyone here get the "Sender Display Name" to work?  I've got the emails working fine, but I never get the Sender Display Name to use what I have entered, and it's confusing as I have a bunch of Jamf servers...
Thank you
RaxiaDK
  • July 11, 2022
Mine Work fine
  • August 26, 2022
Hi, it's not working! I tried this:
- Created an user in Outlook
- Enabled SMTP Auth for that user mailbox.
- smtp.outlook365.com | 587
- TLS1.2 and connection timeout 15sec
Added username (email) and password
Not working!
RaxiaDK
  • August 26, 2022
Not working!
try use your EOP on port 25
  • August 26, 2022
I tried this not working.
  • August 26, 2022
RaxiaDK
  • August 26, 2022
I do this, but look your log
scottb
  • August 26, 2022
Odd, this was working until the 10.40.1 update...now it's not.  This sucks!
scottb
  • August 29, 2022
Well, this may be part of what we're seeing...we recently changed our auth to modern using OKTA verify, so we'll have to see if we can make changes or change to another email solution for this:
Basic Authentication Deprecation in Exchange Online – May 2022 Update
Jay_007
  • June 8, 2023
Yeah, since Microsoft enforced Modern Authentication at the end of 2022, it completely broke this. You can allow Basic Authentication for the single email account to get it working, but this is a security risk.
I suggest putting a vote on this feature request to get Jamf to intergrade with Modern Auth:
https://ideas.jamf.com/ideas/JN-I-16171
  • July 11, 2023
I have done everything as suggested here but its not working for us. What else we need make changes in the both side JAMF pro and M365 side?
Am I correct in thinking that auth should still work if you setup an App Password on an account that has Enforced MFA? As long as you enable SMTP auth on the account it should work with the App Password?
  • November 21, 2023
Worked fine up to begin of November (last succesfull use is from 02/11). Tested yesterday and it is not working anymore.
mvu
Forum|alt.badge.img+22
  • November 30, 2023
Joining the party. Has anybody successfully set up SMTP with Jamf and M365?
  • December 13, 2023
So far (extensive) testing shows that it works once or twice and then stops. We have the idea that MFA kicks in and everything stops.
  • January 4, 2024
Same issue. Looks like port 25 is completely blocked in Jamf Cloud: https://learn.jamf.com/bundle/technical-articles/page/Network_Ports_Used_by_Jamf_Pro.html
"Note: To help keep data and communications as secure as possible, port 25 is blocked in Jamf Cloud. Jamf recommends using port 587 with TLS."
No luck with 587 at the moment either.
  • January 5, 2024
Tried the 587 with various TLS settings and multiple newly created accounts several times and nothing works. It is rather strange though that a new account does work shortly (send once or twice succesfully), before getting blocked. Looks like MFA suddenly kicks in or the address gets blacklisted somewhere?
mvu
  • January 5, 2024
Same here. Since port 25 is blocked, we tried port 587 and 465 with various TLS settings.
Nothing.
We have a ticket in with Microsoft but they are pointing at Jamf. We're stuck. Is it a Jamf or Microsoft thing?
Have you guys looked into your Firewall rules? We're checking to see if the list of new IPs is whitelisted and see if that helps.
https://learn.jamf.com/bundle/technical-articles/page/Permitting_InboundOutbound_Traffic_with_Jamf_Cloud.html
  • January 5, 2024
I did find something about it in a "idea-section" of Jamf (ideas.jamf.com/ideas/JN-I-16171, add https:// in front of it) that refers to it. Looks like they are aware, but not doing much yet about it. And there is a command shown that might help.
  • January 10, 2024
My understanding is that the issue with it working once or twice then stopping is due to new Microsoft default policies kicking in "require MFA" for any users with a risk status of medium or above. This paired up with their recent stricter triggers for risk (new IP, or using smtp), seems to be causing the issue.
Thus.... the oauth/modern auth feature request is becoming even more crucial.
  • February 12, 2024
I spoke with Jamf Support about this the past few weeks. We have an O365 account that has basic authentication and SMTP AUTH enabled, and we used to use it with direct send method before port 25 got shut down by Jamf. We tried to switch to SMTP AUTH configuration, but in Jamf Server logs kept seeing a message about basic auth being disabled for the account (even though it definitely wasn't).
After getting escalated in Jamf Support, we were told that the only way to use O365 as an SMTP server in Jamf now was to use app passwords (which our org has disabled). I tried to press for any information on the roadmap for OAuth and didn't get any response.
mvu
  • February 12, 2024
We got ours to work in Jamf Production and test. We ended up changing a Microsoft Conditional Access policy.
