Hello,
I have a question and a couple of request:
1. If I run a script with API credentials on students' machines, is there a way students can find or check the credentials?
2. I want a working script which will prompt to select a static group and after selecting it, the computer should be automatically added to that particular static group. I have tried many scripts and for some reason its not working. I gave up and decided to get help from this awesome place. I am pretty sure many would have done this and will have a working script.
Thanks.
