we have been having some issues where the configuration profile for the wifi settings are getting corrupted and iOS devices have to have the profile removed and re-applied. its a simple enough thing to work around. I've set the wifi profile to exclude a certain group. all one has to do is connect to an open wifi network, (i use our guest network) add the problem device to the group to remove the profile, wait a couple seconds, and then remove it from the group to have the profile re-apply. simple enough, but something a non-jss-admin user is capable of.
my goal is to put a script into self service that simply prompts for a serial number, then automatically adds and then removes it from the group.
i haven't used the api before and am not sure where to start
thanks
Joe
