Any Teamviewer users out there?
I would like to grab the ClientID from the Teamview plist
Its the 2nd key in the dictionary.
<plist version="1.0">
<dict>
<key>ClientIC</key>
<integer>1869728100</integer>
<key>ClientID</key>
<integer>262023163</integer>
The path to the file is:
~/Library/Preferences/com.TeamViewer.Settings.plist
sed and awk are not my closest friends.
Doug Hanley doug at mac-tek.com - 702-396-0697
Apple Certified Systems Administrator - Apple Certified Trainer
Apple Certified Support Professional - Apple Certified Technical Coordinator
MacTEK Consulting & Training - http://www.Mac-TEK.com
Apple Authorized Training Center (IT & Pro Apps) - Adobe Authorized Training Center
Apple Consultants Network Member - Apple Authorized Service Provider
