I am trying to write a script that will pull the mobile device application id and scope from the API. I'd then like to add a smart group to the scope of certain apps based on their current scoped groups. I have a script that will pull all of my app ids and a script that will pull the scope of an individual app, but I don't know how to create a script that will be able to loop through all of my apps and output the app with its scope.
Pull id for all Apps
jamfUser="api-read"
jamfPass="**********"
jamfURL="https://******.jamfcloud.com/JSSResource"
apiData=$( /usr/bin/curl --user "$jamfUser":"$jamfPass"
--header "Accept: text/xml"
--request GET
$jamfURL/mobiledeviceapplications
echo $apiData | xmllint --format - | xpath "/mobile_device_applications/mobile_device_application" | grep -e "<id>" | awk -F "<id>|</id>" '{print $2}'
Pull scope for specific id
jamfUser="api-read"
jamfPass="*********"
jamfURL="https://*********.jamfcloud.com/JSSResource"
appID="265"
--request GET
$jamfURL/mobiledeviceapplications/id/$appID/subset/Scope )
echo $apiData | xmllint --format - | xpath "/mobile_device_application/scope/mobile_device_groups/mobile_device_group" | grep -e "<name>" | awk -F "<name>|</name>" '{print $2}'
I've added the appID variable because I assume there is a way to write a loop that will loop through all my IDs using some kind of appID + 1 variation.
