Hotspot Not Showing up
  • July 27, 2021
  • 4 replies
  • 41 views
Tony_P
Some of our devices are all ok but some will not display the hotspot feature to even enable. Anyone else experiencing this? If so what was the fix for that issue?
damienbarrett
Forum|alt.badge.img+19
  • July 27, 2021
One of the settings you can set for Supervised devices is the ability to block modifying the Hotspot settings. However, AFAIK, this does not remove the setting; it just disables it (greys it out).
Are you saying that the Hotspot setting isn't even showing up on your devices?
Do you have any configuration profiles you're applying to these devices? Have you checked them to see if you have inadvertently pushed a setting in one of them that may be doing this?
Tony_P
  • July 27, 2021
I checked the settings and Hotspot is not blocked. If that was the case all the devices would have the same issue. It's just there, I've contacted Sprint and reset  network settings and still not working. The option for hotspot is just not even there.
damienbarrett
  • July 27, 2021
Do you have the ability to reset the phone entirely? If so, does it happen after a reset? Is there any commonality between the iPhoneOS on devices that show the hotspot, or devices the don't show the hotspot option?
Tony_P
  • July 27, 2021
When you say reset, you mean wipe and start as new? then no. I did do a network reset though.
