How to configure the proxy setting using MCX or Configuration Profile
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 09-03-2012 08:41 PM
Hi everyone
Could someone help me how could i configure the Proxies for the wire connection using Automatic Proxy Configuration using MCX or Configuration Profile. Please give detail instruction cause i am beginner in JSS.
thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-10-2013 07:41 AM
I am interested in this as well - TY
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-24-2013 09:23 AM
me too
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
me too
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-30-2013 07:29 AM
I believe there isn't a way to do this, unless you are doing it thru WiFi interface only. I don't know why JAMF hasn't set this as a Configuration profile setting. Hopefully in Version 9, the will.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-17-2013 11:06 PM
I found this somewhere else on Jamf Nation
com.apple.systempreferences
Enabled System Preference Panes
If you put in below
and replace
youraddress with your address for your proxy, don't forget
<integer>1</integer> means set
<integer>0</integer> means not set
But i found that by doing this it disables everything in system preferences which I don't want... Im trying various combo's to try and keep everything enabled but having the proxies set....
<dict> <key>ExceptionsList</key> <array> <string>*.local</string> </array> <key>ProxyAutoConfigEnable</key> <integer>1</integer> <key>ProxyAutoConfigURLString</key> <string>youraddress</string> <key>HTTPEnable</key> <integer>1</integer> <key>HTTPPort</key> <integer>8080</integer> <key>HTTPProxy</key> <string>youraddress</string> <key>HTTPSEnable</key> <integer>1</integer> <key>HTTPSPort</key> <integer>8080</integer> <key>HTTPSProxy</key> <string>youraddress</string> <key>FTPEnable</key> <integer>1</integer> <key>FTPPassive</key> <integer>0</integer> <key>FTPPort</key> <integer>8080</integer> <key>FTPProxy</key> <string>youraddress</string> <key>SOCKSEnable</key> <integer>1</integer> <key>SOCKSPort</key> <integer>8080</integer> <key>SOCKSProxy</key> <string>youraddress</string> <key>RTSPEnable</key> <integer>1</integer> <key>RTSPPort</key> <integer>8080</integer> <key>RTSPProxy</key> <string>youraddress</string> <key>GopherEnable</key> <integer>0</integer> <key>GopherPort</key> <integer>0</integer> <key>GopherProxy</key> <string></string> </dict>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-18-2013 02:17 PM
