How to reset DNS for JSS?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 08-11-2008 11:32 AM
I can't seem to find this anywhere... how do I reset the IP Address/DNS
for the JSS? I originally setup the JSS to use a DNS Name, but I now need
to switch it back to an IP Address for use with netbooting.
Thanks,
Tatian Greenleaf
Associate Director of Technology
Saint Mark's School
(415) 472-8000 x1014
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 12:04 AM
That's the thing though...the "Clients" are busted so you have to update the /etc/jamf.conf file on all the clients.
If you use Casper (Remote) to perform this command on anything you can currently talk to this will fix the client piece.
As far as when a new machine gets imaged then you have to do what Thomas suggests as the etc file gets written with the same server as the Casper (Imaging) application uses.
Craig E
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 12:54 AM
Hello,
I just want to clarify what it is you are trying to accomplish. The JAMF configuration file (/etc/jamf.conf) on the client is only used for checking in to the JSS (ie for updating the client's IP and checking for Policies etc), and does not affect NetBoot. In fact, we recommend using a fully qualified DNS name for this.
Your NetBoot server's IP address should be entered in the JSS > Management tab > NetBoot Servers. Once set there, when you tell your clients to NetBoot to a specific server using Casper Remote or a Policy, it will use that IP address.
Please let me know if I am understanding the issue correctly, and if the above will resolve the problem.
Thanks,
Josh
Joshua Holland
Sr. Systems Engineer
JAMF Software
1011 Washington Ave S. #350
Minneapolis, MN 55415
Office (612) 605-6625
Fax (612) 332-9054
http://www.jamfsoftware.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 11:44 AM
I can't answer your specific question (we have only been running Casper
"Tatian Greenleaf" <tgreenleaf at saintmarksschool.org> on August 11, 2008 at 1:32 PM -0500 wrote:
for 10 days, and haven't had our "JumpStart" yet),
but we NetBoot with JSS's DNS name without any problems.
^-O-O-^
+----oOO----(_)--------------+
| Joel Anderson |
| Director of Technology |
| Hibbing Public Schools |
| www.hibbing.k12.mn.us |
+----------------------oOO---+
ooO Ooo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you create your Netboot installer/image it asks you to point it to your casper application. Before you create if, if you hold down the option key and open up Casper.app it will ask you for the JSS info. You can simply put an IP address in there instead of DNS. Or, if you are feeling tricky your client machines store the JSS info in /etc/jamf.conf so you can edit that holds the JSS info.
For example, since I am at my iMac right this moment, I will show you what it looks like:
tlarkin$ cat /etc/jamf.conf
#### jamf.conf -- JAMF Software Configuration File
#### this file will allow Recon, Casper and the jamf command line
#### application to locate the JSS (JAMF Software Server) they need
#### to communicate with
serverAddress = xs001-casper.kckps.org
serverPort = 9006
securePort = 8443
serverPath =
ssl = true
vncPort = 5999
Where it says "server address" you can just put in your IP instead of DNS, and then do a mass copy of that file via ARD admin or a casper policy or whatever.
I think it would be easier to build the netboot image though the way I first explained it.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
office: 913-627-0351
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 11:46 AM
I assume you are netbooting behind NAT? I just did the same thing and since I didn't feel like forwarding a bunch of ports for DNS to go through NAT, I just decided to do that same thing you did and do it by IP address.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Am I right in assuming that will only fix it on that individual client?
I'm looking for a way at the server level, since all of my clients are
trying to connect to the DNS Name and timing out.
Tatian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 11:47 AM
You can run the following command on the clients:
/usr/sbin/jamf createConf -server <IP> -target '/Volumes/Macintosh HD' -port 9006 -securePort 8443 -ssl
Check: /usr/sbin/jamf help createConf
Craig E
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 11:48 AM
Yes, and using the FQDN works just fine
"Thomas Larkin" <tlarki at kckps.org> on August 11, 2008 at 1:46 PM -0500 wrote:
^-O-O-^
| Joel Anderson |
ooO Ooo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-11-2008 11:53 AM
If you are netbooting behind NAT, and want to use an IP instead of DNS
just recreate the netboot image/installer and configure the casper app
to look at the IP instead of the DNS, or modify the /etc/jamf.conf file
like I had mentioned earlier.
Hope that helps you,
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
"Tatian Greenleaf" <tgreenleaf at saintmarksschool.org> 08/11/08 1:51
PM >>>
Tatian
"Ernst, Craig S." <ERNSTCS at uwec.edu> writes: You can run the following command on the clients: /usr/sbin/jamf createConf –server <IP> -target ‘/Volumes/Macintosh HD’ -porrt 9006 –securePort 8443 –ssl Check: /usr/sbin/jamf help createConf Craig E
