Hi All,
I am having hard time finding a solution to something that should be easy thing to do.
More details: I am working on a script that will change the status of a computer that is inactive longer then X days. I am using smart group for the filter and policy to deploy it.
The problem is to run a policy you need a trigger from the computer which is impossible given that the script and policy is for inactive computers to run and it will do the changes from the Jamf server side nothing on the local machine.
Is there a way how I can do this?
