How to write a plist with nested dictionaries from bash script
I'm trying to write a plist from a bash script that has multiple nested dictionaries (dictionary within a dictionary within an array for example).
Right now I'm using the defaults command, which works for normal keys and dictionaries/arrays, but doesn't seem to have support for nested dictionaries/arrays. I need the script to run independently on any mac, so I can't use third party tools that don't come preinstalled on MacOS.
The structure I want to achieve is similar to this image.
  • 1002 replies
  • November 14, 2019
Google using /usr/libexec/PlistBuddy it's in there but hidden away and pretty sure it can do nested stuff.
donmontalvo
Forum|alt.badge.img+36
  • 4293 replies
  • November 14, 2019
NM
Forum|alt.badge.img+31
  • 2721 replies
  • November 15, 2019
PlistBuddy is a plist editor binary that can do nested values, but PlistBuddy is not cfprefsd aware, meaning you will have to kill the app after changing it for the changes to take effect. Just so you don't lose sleep over this small difference thought I would post it.
  • 7880 replies
  • November 15, 2019
It's not well known (I only discovered it recently), but plutil is able to add or insert various values into plist, including adding arrays and entries to those. Here's a page that discusses using it that might help: https://scriptingosx.com/2016/11/editing-property-lists/
They even suggest that it's a good potential replacement to PlistBuddy.
Edit: Just wanted to add that plutil also may not be cfprefsd aware, so it could require restarting cfprefsd to get the altered values read in.
  • 475 replies
  • November 15, 2019
@evangardner Show us the actual xml.
Cookie policy
Cookie settings
