Implementing Jamf PRO
Hi all,
 I have an NFR license with Jamf PRO. I am just trying to download it onto a MacBook to test.
I get this error message here when trying to download the Configuration Profile? I am not sure if this is right way to do this. Is there another way in which I can get Jamf PRO installed onto the MAC, is there a guide I could follow.
Thanks
  • 148 replies
  • March 7, 2023
Not sure what your trying to do here. What is the license for? jamf cloud / jamf on prem or some other product? looks like your manualling installing a currpt config profile.  There isnt a JAMF Pro download for macs anymore
scottb
  • 1285 replies
  • March 7, 2023
Assuming you have a Jamf Cloud NFR, you need to setup an APNS cert; create an enrollment account; and then try to enroll the Mac...
No idea what you've done so far, but that's how to start.
  • March 8, 2023
Hi Scott,
 Yes should have said, this is an NFR license, I have setup the APNS cert. In terms of creating an enrolment account, would that be setting up the Enrolment Invitation ?
Many thanks,
AJPinto
  • 2725 replies
  • March 8, 2023
Have you installed the APNS and MDM Certificates in to JAMF?
  • March 8, 2023
Hi AJ,
 I have installed the APNS and MDM Certificates into JAMF.
Cookie policy
Cookie settings
