Posted on 02-01-2012 03:32 PM
OK, Rachel just rocked our world...
https://yourJSSname:8443/apiResource.rest?resource=networksegments&method=POST
...of course replace "yourJSSname" with FQDN of your JSS.
Don
Posted on 02-13-2012 08:20 PM
Hey Don -
I posted about this under the feature request: https://jamfnation.jamfsoftware.com/featureRequest.html?id=235
But wanted to follow up with you as well. The JSS Subnet Importer: https://jamfnation.jamfsoftware.com/viewProduct.html?id=181 can help with uploading network segments.
There is also a KB: https://jamfnation.jamfsoftware.com/article.html?id=199 that explains how to use it.
Posted on 06-20-2014 04:47 AM
Hey Jake
I tried using the JSS Subnet Importer following the given KB but unfortunately nothing shows up in http://myjsswebsite:8443 tho the log files says success.
We are using JSS 9.2.2 and the user is administrator with full access, not sure how do i proceed further.
Would appreciate if you can guide me how to import the IP Subnets to network segments.
Thanks in anticipation!!
Posted on 01-15-2016 01:32 PM
Anyone know if this works with JSS 9.81 or 9.82?
I know...we can test...but wanted to check first. :)
Don
Posted on 02-13-2019 04:57 AM
#crickets
Anyone know if this works with Jamf Pro 10.7.1, 10.9.0, and 10.10.0 (once released)?
