Infinite Campus > ASM > Jamf PRO Integration
danny33c
New Contributor III
When I was at JNUC in October I talked to some people in the ASM Session who were having trouble with ASM/IC integration. They said that if your instance of IC was cloud hosted it worked ok, but there was an issue with locally hosted Infinite Campus servers. We have locally hosted servers and I’m wondering if those issues have been worked out.
Thanks,
Dan
1 REPLY 1
MattAebly
Contributor II
Contributor II
Hey Dan,
I remember talking with you about the Infinite Campus integration with Apple School Manager. I know there are a lot of customers now using that integration, but I would think that Apple would tell you for sure how the integrations are going. There are still some things to iron out with the SIS integrations, but people are using them.
