Hi guys I have an issue whit one of my scrips on Catalina. The issue is whit TimeMachine logo which should appear as an image on pop up window. Unfortunately Jamf helper shows me that instead of using Accelerated OpenGL is stuccoing on OpneGL and the image is missing. This leads me to think there is a problem whit the API.
Any of you run into that problem ore work around it ?
Instead of using Accelerated OpenGL Jamf stuck's on OpenGL
