Jamf Connect - Is Login still useful for a Filevault machine?
walterchuck
New Contributor
During the below situation, is there any benefit to having Jamf Connect Login installed?
  • Macbook in use for ~1 year by one user. Filevault is enabled. MacOS will not be reinstalled in this instance.
In that workflow, should I not install Jamf Connect Login and its corresponding config profiles and just install Jamf Connect Verify to ensure their password's synced while logged onto Finder? Is there any other feature I'd be missing out on?
In a workflow that includes reinstalling MacOS, I intend to keep Login to handle the out of box experience as well as creating the user accounts with admin/standard privileges.
0 REPLIES 0
