jamf imaging can not be opened
jun_zhang
New Contributor II
After upgrade JAMF pro to 10.23, the jamf imaging application can boot. It stuck on get serial number.
My OS version is 10.15.5
1 REPLY 1
lucas_nelson
Community Manager
Community Manager
Hey @jun.zhang,
Apple officially deprecated and suggested against block-copy or monolithic based imaging as of 10.13.4 I believe. While it has worked in some fashion since then, Apple's official stance is those computers are not correctly provisioned.
https://support.apple.com/en-us/HT208020
While we ship Jamf Imaging as part of the Jamf Pro Installation, it is for backwards compatibility purposes only. Feel free to reach out to Jamf Support to speak about alternative methods for installing macOS at your organization. We should be able to find a supported method to get you rolling.
Thank you for reaching out, and I apologize that this is causing some hiccups in your workflow!
