Jamf Inventory Display Order Customization?
The way JAMF displays my inventory requires me to scroll a lot to the right to find information on an asset. I would like to customize the order the columns are displayed. For example, Asset, serial number, building, and then room. Is it possible to change the order of the inventory display?
  • 7880 replies
  • July 11, 2017
You can't change the order, but you can turn off some unnecessary columns to make the display shorter in width. It can be convenient to have a lot of fields show up, but can lead to a lot of scrolling to the right as you are finding. But in terms of moving them into a different order, that isn't possible to do with the current version. I'm hoping such a feature will be coming in a future release though.
  • July 11, 2023
I'm curious why, in 2023, would you not offer the ability to sort columns?
M4tr1xN3o
  • 12 replies
  • September 9, 2023
Completely agree. Why are we still not able to customise column layout on reports and inventory screens ðŸ˜§
Cookie policy
Cookie settings
