Jamf Management Actions appearing outside of Notification Center?
markopolo
Contributor
Getting a weird issue where notices for Management Actions (software updates, user prompts, etc.) are floating outside in their own little translucent window (see below) instead of tethered to the Notification Center like they should be. Not sure how widespread the issue is yet. We are using a profile to auto-allow Jamf Notifications (com.jamfsoftware.Management-Action) that has been working fine up until now. Has anyone seen this before or know what's causing it?
4 REPLIES 4
markopolo
Contributor
Or is this just how it works when you add a user-selected deferral to the policy (just occurred to me)? This is the first time I'm doing that.
Yeaaaaah... That was it. Lol.
emily
Valued Contributor III
Yep! That’s how the management action window looks when a deferral option is set.
bwoods
Valued Contributor
Beyond Trust and Global Protect. I like your style.
