Jamf Trust - How to guide a user to enable JamfPrivateAccess ?
tleadley
New Contributor II
 I have been able to determine if the application is enabled and running, just have not been able to create a script or guidance to help the user turn it back on without generating support tickets. I have seen this type of guidance demonstrated with a Jamf lead learning presentation.
So what I want to do is create an alert that will guide a user to a self service help script that will either direct a user to or allow them to click a button to enable Jamf Private Access when it gets disabled.
Anyone have any Ideas?
I have not been fruitful in my search of information as of yet to be able to run JamfPrivateAccess using CLI or create the assistive guidance necessary.
1 ACCEPTED SOLUTION
tleadley
New Contributor II
Since I have not found or heard anything, I have attempted to create this myself. Here is my multi pronged approach, this is not a perfect method however it does work and does a pretty good job. All done without generating embedded credentials to make this process work. I have tried to cover as much as I can.
If there are other Ideas or improvements please share!
When the status is set to Not running or Access_Disabled the device will be added to the following:
Smart Group
Jamf Trusted Access Disabled
Status for EA’s
EA Name
Status Message
Jamf Trust - Access
Running
Not Running
Jamf Protect - Smart Groups
Access_Disabled
Jamf Protect custom analytic with smart group
Jamf Protect agent will notify and update smart group when the application has been disabled or closed
( $event.type  == 2 AND $event.process.name == "JamfPrivateAccess" )
Jamf EA
Purpose is to detect if the Jamf Trust Access process is running when the device checks in.
EA Name: Jamf Trust - Access
Script:
ProcessName=JamfPrivateAccess
number=$(ps aux | grep -v grep | grep -ci $ProcessName)
if [ "$number" = "1" ]
    then
        result="Running"
    elif [ "$number" = "0" ]
    then
        result="Not Running"
Jamf Helper script
Computer Management script named Jamf Access Disabled
This is the script that notifies the end user and will allow the user to enable Jamf Trust Access and if for some reason the workflow is not installed it will not show the enable button unless the workflow is installed.
## Get the logged in username
currUser=$(/usr/bin/stat -f%Su /dev/console)
# Jamf Helper Script for Jamf Protect (Low-Level Threat)
jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper"
#Title for Pop Up
msgtitle="Digital IT Group"
#Header for Pop Up
heading="Jamf Private Access"
#Description for Pop Up
description1="Looks Like Jamf Access has stopped running!
If this is something you have initiated you can disregard this message.
Otherwise if this becomes persistent, Please report to IT."
description2="Looks Like Jamf Access has stopped running!
If this is something you have initiated you can disregard this message,
Otherwise Click Enable to reactivate your connection!
Please report to IT if you suspect anything wrong or if this becomes persistent."
#Button Text
button1="Ok"
#Button Text
button2="Enable"
#Path for Icon Displayed
icon="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/ToolBarInfo.icns"
if [ ! -d /Users/$currUser/Library/Services/access.workflow ]; then
userChoice=$("$jamfHelper" -windowType utility -title "$msgtitle" -heading "$heading" -description "$description1" -button1 "$button1" -icon "$icon")
userChoice=$("$jamfHelper" -windowType utility -title "$msgtitle" -heading "$heading" -description "$description2" -button1 "$button1" -button2 "$button2" -icon "$icon")
if [[ "$userChoice" == "2" ]]; then
/usr/bin/automator /Users/$currUser/Library/Services/access.workflow
#Remove Jamf Protect Extension Attribute
rm /Library/Application\ Support/JamfProtect/groups/*
#Update Jamf Inventroy
jamf recon
Created Jamf Pro "PKG" signed build that installs the workflow, with post install script borrowed from @mm2270
This community article
## Check for a 'Services' folder in the user's home directory. Create one if necessary
if [ ! -d /Users/$currUser/Library/Services ]; then
    echo "Creating Services directory for $currUser"
    mkdir /Users/$currUser/Library/Services
    sudo chown -R $currUser /Users/$currUser/Library/Services
## Check to see if the workflow file was installed in /tmp
## and copy it to the current user's home Library folder
if [ -d /private/tmp/access.workflow ]; then
    sudo cp -R /private/tmp/access.workflow /Users/$currUser/Library/Services/
        echo "Copied the workflow to $currUser's Services folder"
    sudo chown -R $currUser /Users/$currUser/Library/Services/access.workflow
        echo "Set permissions on the workflow to $currUser as owner"
    sudo chmod -R go-rwx /Users/$currUser/Library/Services/access.workflow
        echo "Set access on the workflow for $currUser"
    ## Exit the rest of the installation if the workflow wasn't there to copy
    echo "The Service workflow was not found. Exiting installation..."
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -title "Installation failed" -description "We seem to have run into a problem getting the service installed for you. Try running the Self Service installation again. If you continue to see this error, contact support so we can help correct this for you." -icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/AlertCautionIcon.icns" -button1 "OK" -defaultButton 1
    exit 1
## Now we check to make sure everything is in place
if [ -e /Users/$currUser/Library/Services/access.workflow ]; then
    echo "The Service was installed"
    serviceFile="Yes"
sleep 2
killall Finder
## Final clean up stage
rm -R /private/tmp/access*
Apple Automation workflow
Record a simple workflow to record your action to click the menu item to enable the feature. Note this will also disable access since it only clicks the menu item shown if the user has already enabled before the process kicks off
Application accessibility enablement payload
Since we are activating this workflow within terminal, terminal only needs access to activate this automation and I used PPPC Utility to allow accessibility permissions and then upload.
Identifier: com.apple.Terminal
Identifier Type: Bundle ID
Code Requirement : identifier "com.apple.Terminal" and anchor apple
Accessibility  : Allow
Tools Used
Composer
PPPC Utility
Jamf Admin
KeyChain Access
Text editor
3 REPLIES 3
tleadley
New Contributor II
Smart Group
Status for EA’s
EA Name
Status Message
Jamf Trust - Access
Running
Not Running
Access_Disabled
Jamf EA
Script:
    then
        result="Running"
    then
Jamf Helper script
#Title for Pop Up
#Header for Pop Up
#Button Text
button1="Ok"
#Button Text
button2="Enable"
jamf recon
    exit 1
    serviceFile="Yes"
sleep 2
killall Finder
Tools Used
Composer
PPPC Utility
Jamf Admin
KeyChain Access
Text editor
jonbrown2
New Contributor
@tleadley is this still working for you? I only ask because I tested this hoping it would work for us, JAMF Trust (Private Access), still does not automatically connect on login, restart or sometimes just disconnects.
I have implemented the Terminal PPPC for Accessibility: Allow yet when I run the workflow in JAMF Pro via the script above I get
The action “Watch Me Do” encountered an error: “This application must be allowed to control this computer using accessibility features, using the Security & Privacy preferences located in System Preferences, before using 'Watch Me Do"
The script works fine locally and runs with/without admin access and the workflow runs fine when I run
as well.
tleadley
New Contributor II
I have had to update this in recent times since initially creating this I have removed the apple automation, it is too unreliable.
I have created a script so it loads at login and I do this on enrollment, it creates the autolaunch and only once per computer
#!/bin/zsh
## Current User
CURRENT_USER=$(ls -l /dev/console | awk '{print $3}')
CURRENT_USER_UID=$(id -u $CURRENT_USER)
launchctl asuser $CURRENT_USER_UID osascript -e 'tell application "System Events" to make login item at end with properties {name: "Jamf Trust",path:"/Applications/Jamf Trust.app", hidden:false}'
Jamf Support suggests, running this line in a policy that runs once a week
open -a "Jamf Trust" "com.jamf.trust://?action=open"
