Kaspersky no longer installing on 12.3 using pkg
  • March 25, 2022
  • 16 views
EngineerO
Hi folks,
I am looking to see if anyone can help me with this issue.
We have been deploying the Kaspersky agent, and a separate PKG file for the Endpoint Security.
After 12.3 this suddenly stopped working. When opening the Kaspersky DMG, and going through the setup, it works fine.
But when opening the PKG files, it fails in the end. This broke after 12.3
Would anyone have any advice where to start to get this working again?
2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: allow user idle system sleep 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “Kaspersky Endpoint Security.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file:///Volumes/Kaspersky%20Endpoint%20Security/Kaspersky%20Downloader.app/Contents/Packages/Kaspersky%20Endpoint%20Security.pkg#core.pkg, PKInstallPackageIdentifier=com.kaspersky.kav.core, NSLocalizedDescription=An error occurred while running scripts from the package “Kaspersky Endpoint Security.pkg”.} { NSFilePath = "./postinstall"; NSLocalizedDescription = "An error occurred while running scripts from the package \\U201cKaspersky Endpoint Security.pkg\\U201d."; NSURL = "file:///Volumes/Kaspersky%20Endpoint%20Security/Kaspersky%20Downloader.app/Contents/Packages/Kaspersky%20Endpoint%20Security.pkg#core.pkg"; PKInstallPackageIdentifier = "com.kaspersky.kav.core"; } 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Cleared responsibility for install from 57999. 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Cleared permissions on Installer.app 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Running idle tasks 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Done with sandbox removals 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias Installer[57999]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “Kaspersky Endpoint Security.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file:///Volumes/Kaspersky%20Endpoint%20Security/Kaspersky%20Downloader.app/Contents/Packages/Kaspersky%20Endpoint%20Security.pkg#core.pkg, PKInstallPackageIdentifier=com.kaspersky.kav.core, NSLocalizedDescription=An error occurred while running scripts from the package “Kaspersky Endpoint Security.pkg”.} 2022-03-25 14:02:53+01 FVFGK2WPQ05N-tobias installd[56592]: PackageKit: Removing client PKInstallDaemonClient pid=57999, uid=502 (/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer) 2022-03-25 14:02:54+01 FVFGK2WPQ05N-tobias Installer[57999]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. 2022-03-25 14:02:54+01 FVFGK2WPQ05N-tobias Installer[57999]: IFDInstallController E35A0 state = 8 2022-03-25 14:02:54+01 FVFGK2WPQ05N-tobias Installer[57999]: Displaying 'Install Failed' UI. 2022-03-25 14:02:54+01 FVFGK2WPQ05N-tobias Installer[57999]: 'Install Failed' UI displayed message:'The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.'. 2022-03-25 14:04:37+01 FVFGK2WPQ05N-tobias Installer[57999]: Package Removal: User opted to keep package.
1 reply
EngineerO
  • March 25, 2022
Additionally:
The Deployment through the Kaspersky Server never worked for us at MacOS, gets stuck at 51% that's why we are using the PKG file.
