keyboard layout smart group
  • February 6, 2020
  • 38 views
dbruyere
Hello,
I would need a script for an attribute extension which I would use to trace what type of keyboard is used on computers and to create smart groups.
Do you have any ideas ?
Thank you.
dsavageED
  • February 6, 2020
To what end are you wanting to gather this information? The settings involved are stored at a user level, so populating an extension attribute with the value isn't the easiest thing. The preference holding the keyboard info is com.apple.HIToolbox.plist If you simply wanted to set a default keyboard layout then a custom configuration profile would work. The settings, depending on your region etc, would look something like:
<plist version="1.0">
    <dict>
        <key>AppleCurrentKeyboardLayoutInputSourceID</key>
        <string>com.apple.keylayout.British</string>
        <key>AppleEnabledInputSources</key>
        <array>
            <dict>
                <key>InputSourceKind</key>
                <string>Keyboard Layout</string>
                <key>KeyboardLayout ID</key>
                <integer>2</integer>
                <key>KeyboardLayout Name</key>
                <string>British</string>
            </dict>
        </array>
        <key>AppleSelectedInputSources</key>
        <array>
            <dict>
            </dict>
        </array>
    </dict>
</plist>
You can read in the info from this plist, but any code will fail when a user isn't logged in, making it iffy to use for scoping, especially when you add in the fact that a multi-user system could have multiple answers...
dbruyere
  • February 6, 2020
I do not wish to define a setting but to provide information for my inventory.
If it's possible :)
Regards,
dsavageED
  • February 6, 2020
Sorry, are you wanting to gather the physical type of keyboard attached to a Mac, or the keyboard layout/language that a user is using?
For the physical device; "ioreg -p IOUSB" is probably the best bet, but actually working out a sensible match isn't always obvious... For example:
CHERRY KEYBOARD@14500000 <class AppleUSBDevice, id 0x1000003b7, registered, matched, active, busy 0 (0 ms), retain 13>
USB Keyboard@14300000 <class AppleUSBDevice, id 0x10000034b, registered, matched, active, busy 0 (0 ms), retain 13>
Apple Keyboard@14420000 <class AppleUSBDevice, id 0x1000003ac, registered, matched, active, busy 0 (0 ms), retain 13>
Are all keyboards... "system_profiler SPUSBDataType" might be more human readable, but will also be harder to filter.
For the language, you would need to pull the info from that plist. Something like: defaults read com.apple.HIToolbox AppleSelectedInputSources | grep "KeyboardLayout Name"
Note this code would need to be ran as the user, or you would need to specify the full path /Users/USERNAME/Library/Preferences/com.apple.HIToolbox
