Posted on 10-04-2013 06:55 AM
Hello,
New to Casper - would like to know if I can downlowad/buy a version of casper to test in my home lab? and would one mac mini server serve as my JSS and distribution point?
Solved! Go to Solution.
Posted on 10-04-2013 07:42 AM
I use our same activation code in our dev environment and it's ridiculously handy.
Posted on 10-04-2013 07:15 AM
I believe JAMF will allow you to install and use your production license for a lab environment free of charge.
Posted on 10-04-2013 07:44 AM
Posted on 10-04-2013 09:37 AM
You can ask the sales rep for a separate dev code as well.
Posted on 10-07-2013 02:08 AM
We obtained an evaluation code from our supplier for 30 days to test Casper before purchasing. Used an iMac as the test server and worked well.
The type of Mac to use as the JSS will depend on how many devices you were looking at managing.
