Hi guys,
We are rolling out Jamf Pro to our estate.   Jamf pro itself is hosted in the cloud.   As a standard security procedure, we would like to limit access to the Administration web app not only to certain users, but certain IPs.   Is there any way to do this, bearing in mind we don't have access to the tomcat config?
This sounds like something that would be prefect for federated authentication or SSO. Since most SSO providers can filter by IP, you should be able to set up rules on the SSO platform to only allow the IP ranges that you want for that specific resource.
