Posted on 10-11-2018 05:12 AM
When we had AirWatch they had a feature where you could set up a shared device. You had an agent app that you would log in and out of and it would pull down all profiles and settings that were assigned to that user. We also had active sync setup with native mail.
In JAMF we have moved to Outlook mobile and there doesn't seem to be a way to log in and out. In Outlook we have the users set up their account which is using O365 Modern Auth. I would like some way to remove these accounts when they check them back in. What options do I have with JAMF?
Posted on 10-11-2018 05:36 AM
id be quite interested in seeing response to this - its something we have begun looking at...
currently i will just wipe the device to reset, as its supervised by the JSS it doesnt matter if they are logged into iCloud or not as the JSS can still unlock the phone for reuse
Posted on 10-15-2018 06:57 PM
I guess no ones does this setup...
Posted on 10-17-2018 08:17 AM
Yea, that's what we do. We keep a loaner phone or two, but we're DEP and just wipe the loaner when it's returned and set it up anew.
Posted on 10-17-2018 07:11 PM
Ok makes sense
