Location mass modify in devices (Jamf Pro)
arajabzadeh
New Contributor III
Hey Guys
is there anyway we can edit the location in a specific smart group members ? we have 50 devices which has the location e.g Y1 and I want to change the Room criteria to Y2 .
Thanks
Arman
2 REPLIES 2
stevewood
Honored Contributor II
The MUT is probably the easiest way, IMO. Export the Smart Group and use the serial number of the devices from that CSV to fill out one of the MUT templates to update in Jamf Pro.
revive
Contributor
I second Stevewood's answer.
Use MUT and Numbers application by Apple. Pull a report with the device name, serial number, specs and location.
From there change the column for what you want to accomplish and it should reflect very quickly.
If you havent use it before, i would run a couple of tests on your machine and maybe some other people.
