Lock a computer entry
  • September 25, 2020
  • 0 views
Is there a way to lock a computer entry in Jamf. Something that would alert another admin against deleting it. Maybe you sent a lock command to a computer of a former employee and want to safeguard against the entry being deleted before the laptop is returned.
1 reply
  • 7880 replies
Not that I'm aware of. If the account logged into Jamf Pro has computer object deletion rights, then it applies to all computers. I don't think you can specify certain ones to not be deleted.
You could put a note somewhere in the device record as a warning, but those are usually buried somewhere and not very visible when just looking at the device under a search for example.
The only other thing I can think to do, specifically in the use case you mentioned where you've sent a Lock command to it, is to rename the device record in Jamf Pro, by adding something like "-DO-NOT-DELETE" to the end of it perhaps. This won't actually rename the Mac itself. The Jamf device record should retain that name until the Mac checks back in again and performs an inventory collection, which won't happen right away if you've issued a remote lock to it. Just something to think about.
Cookie policy
Cookie settings
