Look! Another naming script post!
easyedc
  • 623 replies
Over the years, with new OS's releasing, I've been tweaking a naming script that changes all the computer names AND changes the hard drive name (we use that as a quick reference for users for support issues). I can rename the computer all day long, but with APFS volumes out there, I'm looking for better solutions.
base="MK"
serial=`/usr/sbin/system_profiler SPHardwareDataType | /usr/bin/awk '/Serial Number (system)/ {print $NF}'`
/usr/sbin/scutil --set ComputerName "${base}${serial}"
/usr/sbin/scutil --set LocalHostName "${base}${serial}"
/usr/sbin/scutil --set HostName "${base}${serial}"
HDDName=`/usr/sbin/diskutil list | grep "Macintosh HD" | grep disk0`
HDDCSName=`/usr/sbin/diskutil list | grep "Macintosh HD" | grep disk1`
UntName=`/usr/sbin/diskutil list | grep "Untitled 1" | grep disk0`
Unt2Name=`/usr/sbin/diskutil list | grep "Untitled 1" | grep disk1`
if [ "$HDDName" != "" ]; then
    diskutil rename disk0s2 "${base}${serial}"
elif [ "$HDDCSName" != "" ]; then
    diskutil rename disk1 "${base}${serial}"
elif [ "$UntName" != "" ]; then
elif [ "$Unt2Name" != "" ]; then
The script is based on 2 assumptions. Either a) the drive is brand new out of the box and named "Macintosh HD" or it was wiped and imaged and in the image the drive name was intentionally left as "Untitled 1" but with the addition of APFS vs JFHS+ a new wrinkle emerges. I assume that I could simplify this with something along the lines of a grep around
disk1s1
or
disk0s1
But before I go through that trial/error testing, I wanted to ask if anyone else has a simpler or prettier method to accomplish my goal or suggestions in general?
Thanks
Be the first to reply!
Cookie policy
Cookie settings
