Posted on 02-22-2019 08:20 AM
I own a MacBook Pro Early 2011 13" i5 2.3 GHz model
Lately as my MacBook was shutting down randomly I fiddled with it a lot and finally I messed with its Wifi.(I do not remember how I did it as I was under a lot of stress and pressure while doing so)
Currently my wifi works only during disk selection stage and once I enter recovery mode (where we see the disk utility ,terminal etc) or boot screen I see the wifi is turned off and even if I try to enable it it just does not turn on.
Kindly help and please see the pictures showing that wifi works during disk selection stage where it can list all the available networks and i can join any using the password, and show how the icon stays after booting but I can't connect/enable WiFi.
Explanation of pictures: CLOCKWISE
-option to jion wifi at disk selection stage -it successfully ahows available networks -etenteredpassword and joined Nirvana successfullly -BUT THE WIFI DOESNOT WORK ONCE I LOGIN TO MY ACCOUNT ...i mena after the booting up of system Things I did to rectify the problem:
I have downgraded to Yosemite and changed my motherboard (now the switching off is gone)
I remember doing something like that some 801gfile.kext ....for which i used some utility where it checked the missing kext and seems to have replaced the missing ones...but to no avail.
reinstalled and clean installed macos
This wifi fiddling I did was on old motherboard. Even on new board the problem remains. The problem first surfaced on the old board.
MY BLUETOOTH WORKS FINE
Accessing internet: Currently i am using ethernet and external usb wifi dongle by tinda to access internet
Answers for comments - i have replaced only the mother board.the wifi card is the same as before.the problem used to be there even with old motherboard. As said the wifi card currently works fine during disk selection stage where i can select different networks and join them..but ones i enter recovery mode or boot the os normal or safe mode the wifi doesnot turn on
-i have the same old wifi cable and card on the current system..only the mother board was changed. the bluetooth works fine..
Kindly help please.....
Nanis-MacBook-Pro:~ Nani$ kextstat | grep -A10 'IO80211'
46 1 0xffffff7f8180f000 0xab000 0xab000 com.apple.iokit.IO80211Family (730.60) <44 10 7 6 5 4 3 1>
48 0 0xffffff7f81f1b000 0x1f3000 0x1f3000 com.apple.driver.AirPort.Brcm4331 (800.20.24) <46 44 12 7 5 4 3 1>
49 2 0xffffff7f81024000 0x73000 0x73000 com.apple.iokit.IOFireWireFamily (4.5.8) <5 4 3 1>
50 0 0xffffff7f815f3000 0x27000 0x27000 com.apple.driver.AppleFWOHCI (5.5.2) <49 12 7 6 5 4 3 1>
51 0 0xffffff7f8253d000 0x13000 0x13000 com.apple.driver.AppleSDXC (1.6.5) <16 15 12 5 4 3 1>
52 1 0xffffff7f814fb000 0x7000 0x7000 com.apple.iokit.IOEthernetAVBController (1.0.3b3) <44 5 4 3 1>
53 0 0xffffff7f81502000 0x39000 0x39000 com.apple.iokit.AppleBCM5701Ethernet (10.1.3) <52 45 44 12 11 6 5 4 3 1>
55 0 0xffffff7f817ea000 0x18000 0x18000 com.apple.iokit.IOAHCIBlockStorage (2.7.1) <39 16 6 5 4 3 1>
56 0 0xffffff7f812be000 0x1c000 0x1c000 com.apple.driver.AppleUSBHub (705.4.2) <41 5 4 3 1>
57 0 0xffffff7f82321000 0x3000 0x3000 com.apple.driver.XsanFilter (404) <16 5 4 3 1>
58 0 0xffffff7f8224d000 0xa000 0xa000 com.apple.BootCache (36) <7 6 5 4 3 1>
