Posted on β10-08-2019 12:09 PM
Hello,
Since /Library/Preferences/OpenDirectory/Configurations is now locked (RO) we are no longer able to populate our custom ldap mappings.
dsconfigldap does not provide a way to import template and manually configuring hundreds of computers is not an option. Does anyone have a plan on how to do this ?
Config Profiles do not have Mappings for LDAP, only for Active Directory.
Mike
Posted on β11-26-2019 02:54 PM
Hi Mike,
I'm experiencing the same challenge and am just beginning to search for a solution. Please post here if you find a solution and I'll do the same.
Posted on β04-01-2020 09:27 AM
We did add some stuff in our ldap. If you are interested in iβll check for. There is no other way tgan oulling the mappings from ldap. Ad is here easier.
Mike
