macOS 12.5 wifi connect problem
  • September 22, 2022
  • 24 views
Please let me know if you have problem with wifi connection to corporate network after upgrade macOS to version 12.5. Now in our environment every Macbook prompt users for credentials before connect to wifi instead of using installed certificate. In version 12.4 everything worked fine. I would be grateful for the tips. Thanks!
coachdnadel
Assuming your devices are still bound, unbind and rebind should do the trick. I have to do that process with 3 or 4 devices a day in my environment.
donmontalvo
Forum|alt.badge.img+36
Did you test on 12.6?
  • September 23, 2022
Of course... I should have done this firstly :) Upgrade to 12.6 resolved the problem. Thanks a lot!
