Posted on 11-24-2015 07:39 AM
Hi Guys,
Been kind of confused as to why Maps and Calendar location would stop working the minute we install Casper quickadd to our laptops. Without Casper, Maps and Calendar works perfectly, but with it it just draws a blank page when Maps are opened. Any thoughts?
Posted on 11-24-2015 08:21 AM
Do you have anything configured that blocks location services?
Posted on 11-24-2015 09:37 AM
Hi there,
Nothing configured that will block the location services. Weird thing is, if I delete the plists, restart the machine while Casper is installed: Then open Maps, it works. But when I quit, then open Maps again then it stops working, iCal as well. Locations stops to work at this point even after deleting the plist (without restarting).
And of course our laptops that are clean with no Casper works just fine.
Posted on 11-24-2015 09:46 AM
The only time I've ever seen something like that was installing OSX into a virtual machine like in Parallels or VMware. There are a lot of things that don't work when virtualized like location services and even the account avatar icon. You didn't build the master image from a virtual machine, did you?
Posted on 11-24-2015 10:23 AM
Thanks for the response AVmcclint.
No, these couple of laptops that I'm troubleshooting are straight out of the box (OS X 10.11.1) and installed only Casper.
UPDATE:
Removed Casper from one of the new laptops. Maps an iCal have been working consistently and no issues so far.
