Posted on
08-16-2018
08:43 AM
- last edited on
03-04-2025
04:25 AM
by
kh-richa_mig
Hello
We have a high school with +400 iOS devices in Airwatch we are going to be moving to Jamf Pro. I've been contracted to engineer the project.
I am not sure yet if these devices are DEP enabled or not. (Some will be personally owned, some are owned by the institution)
Ideally we want to make this as seamless as possible. I.e unenroll the device from AW and enroll into Jamf withoutItalicText
having to reset the device or loose any MDM installed apps.
I'd like to avoid students loosing app data on their institution assigned device.
Is that possible? Or would it be best practice to reset the (institution) device and then start from scratch by either using DEP enrollment (if available) / user base enrollment and then re-push everything.
Will the personal devices also have their MDM assigned apps removed and reinstalled during the VPP token and MDM migration?
Thoughts?
Posted on 08-22-2018 10:11 AM
In AW, if DEP, the MDM profile is probably configured as not removable.
With a new APNS certificate and MDM URL, I think you should be starting from scratch. We'll see if anyone else chimes in.
Posted on 08-22-2018 04:46 PM
When we moved from Airwatch to Jamf Pro MDM, we wiped the iPads and started again, although these were not devices with user data on.
