Monitor / block installation of unauthorised apps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
03-09-2018
12:50 AM
- last edited on
03-04-2025
09:36 AM
by
kh-richa_mig
Is there a way we can monitor and/or block installation of unauthorised applications by non-administrators on macOS, while still allowing them to install authorised applications through Self Service?
Thanks,
Dan Jackson (Senior ITServices Technician)
Long Road Sixth Form College
Cambridge, UK.
- Labels:
Self Service
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-09-2018 08:44 AM
You could try "restricted software" to do this and type in all the apps to kill the process and delete the app from the machines of non-administrators through a smart group.
The better option may be to use "Configuration Profile" > Restrictions > and uncheck "allow non-admins to install..." you could also restrict the applications allowed to launch and further refine this by also using a smart group of the machines not-owned by an admin (unless you have multiple users per machine and in that case just uncheck "allow non admins"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-12-2018 08:26 AM
@al786 The "Require admin password to install or update apps" setting is the one at issue. With this enabled, the user is unable to install a Mac App Store app from Self Service (they are prompted for admin credentials by "storedownloadd").
I was wondering, if I was to uncheck this setting, whether I could monitor or prevent students from installing other apps (for example from downloads or from USB sticks).
