Need Help Converting a Script for Jamf
  • April 25, 2022
  • 11 replies
  • 77 views
Hello all!
We are testing a new software that is installed through a script. However, this software requires the end user input for activation keys. I'm looking to apply this through Jamf but in a way that does not require the end user to do anything at all.
#!/bin/bash declare account_key declare organization_key declare tags declare api_url declare eetee_url declare allow_http=false declare verbose=0 declare interactive=1 declare -a ARGS declare portal_url="https://huntress.io" declare package_file= ARGS=() usage() { cat <<EOF Usage: $0 [options...] --account_key <account_key> --organization_key <organization_key> -a, --account_key <account_key> The account key to use for this agent install -o, --organization_key <organization_key> The org key to use for this agent install -t, --tags <tags> A comma-separated list of agent tags -v, --verbose Print info during install --batch_only Do not prompt the user for missing info -h, --help Print this message EOF } while [[ $# -gt 0 ]]; do key="$1" case $key in -a|--account_key) account_key="$2" shift shift ;; --batch_only) interactive=0 shift ;; -o|--organization_key) organization_key="$2" shift shift ;; -t|--tags) tags="$2" shift shift ;; -v|--verbose) verbose=1 shift ;; -h|--help) usage exit ;; # these are more or less hidden options. Only used for debugging -f|--package-file) package_file="$2" shift shift ;; -p|--portal_url|--portal-url) portal_url="$2" shift shift ;; -u|--api_url|--api-url) api_url="$2" allow_http=true shift shift ;; --eetee_url|--eetee-url) eetee_url="$2" allow_http=true shift shift ;; *) ARGS+=($1) shift ;; esac done set -- "${ARGS[@]}" # ask the user for the account key if not passed in and we are # "interactive" (see --batch_only) if [[ -z $account_key && $interactive -eq 1 ]] then echo -n "Account Key: " read account_key fi # ask the user for the organization key if not passed in and we are # "interactive" (see --batch_only) if [[ -z $organization_key && $interactive -eq 1 ]] then echo -n "Organization Key: " read organization_key fi # account key and organization key are required if [[ -z $account_key || -z $organization_key ]] then echo Error: --account_key and --organization_key are both required echo usage exit 1 fi declare installer_config="/tmp/hagent.yaml" [[ $verbose -eq 1 ]] && echo creating "$installer_config"... # create the hagent.yaml file used by the postinstall script to build # the AgentConfig.plist file cat >"$installer_config" <<EOF account_key: $account_key organization_key: $organization_key api_url: $api_url allow_http: $allow_http tags: $tags EOF if [ -n "$eetee_url" ]; then echo "eetee_url: $eetee_url" >>"$installer_config" fi huntress_pkg=/tmp/HuntressAgent.pkg if [ -n "$package_file" ]; then if [ -f "$package_file" ]; then cp -f "$package_file" "$huntress_pkg" else echo "$package_file" was not found exit 1 fi else # download the HuntressAgent.pkg file from S3 status_code=$(curl -f -L -o "$huntress_pkg" -w %{http_code} "$portal_url/download/darwin/$account_key") if [ $? != 0 ]; then if [ "$status_code" = "400" ]; then echo "Account Key not valid." elif [ "$status_code" = "404" ]; then echo "File not found on S3." elif [ "$status_code" = "409" ]; then echo "The macOS Beta has not been enabled for this account." fi exit 1 elif ! [ -f "$huntress_pkg" ]; then echo "File download failed." exit 1 fi fi [[ $verbose -eq 1 ]] && echo running the installer... # run the install installer -pkg "$huntress_pkg" -target / || echo "Installation failed." [[ $verbose -eq 1 ]] && echo cleaning up... rm "$installer_config" rm "$huntress_pkg"
Let me know if you can point me in the right direction. I'm new to scripting and definitely need assistance on this one.
Thanks
You might think about using GitHub or some other repository system to host that script snippet, or even just in line using the formatting. A link to a personal file in your companies Sharepoint is not really a good idea on a public forum.
  • April 25, 2022
Thanks for your input. I'm well aware of this. The link is set to expire. Do you have any other input regarding my actual question/request?
Nope, didn't open the link.
  • April 25, 2022
I updated the post and added the script. Thanks @andrew_nicholas
You might want to scrap the current logged in user and then leverage the osascript to get a prompt the user can enter. Something like this should do it
currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{print $3}') getInput() { /usr/bin/osascript <<END set nameentry to text returned of (display dialog "[Your text goes here]" default answer "" with hidden answer buttons {"Enter", "Cancel"} default button 1 with icon 2) END } input=$(getInput)
I completely missed your thing about not getting any user interaction. Judging by the flags they listed, you should be able to just use scriptname -a [key] -o organization. The vendor might have something they'd suggest but Im guessing that is all that's needed.
  • April 25, 2022
I'm gonna kick myself. I must have skimmed right over that. So really the process in a Jamf script would download this script and then execute the downloaded script with the flags -a and -o. Am I in the right ball park here?
Yea I think so. Happy Hunting?
Forum|alt.badge.img+20
  • April 25, 2022
Looking at the code, the script is actually cycling through the command line arguments. You could try using the script parameter values in jamf. You would need to use both the argument name and the value. For example
Parameter 4 = -a <<account key>>
Parameter 5 = -o <<organization name>>
etc.
I would also include the "--batch_only" parameter as well.
  • May 20, 2022
etc.
@Tribruin Thank you for this. From what you looked at would I need to adjust anything in the script itself? Or would I simply fill in the parameters 4 and 5 as you recommended above?
  • May 20, 2022
From what I am seeing, no you should not need to change the script. It already cycles through all arguments, so it will find the arguments. But, test heavily.
You might also check with the vendor that supplied the script and see if they know of any customers that have implemented it in Jamf.
