Need Jamf Api Help
Hello,
I am new to jamf and api
I am trying to understand jamf api. I am trying to update the information under ios device - user and location - department. add or remove the information
here is the basic code i wrote from piece mealing from different place but no luck
    -H "content-type: application/xml"
    -H "accept: application/xml"
    -d "<mobiledevices><location><department>Students</department></location></mobiledevices>"
stevewood
Forum|alt.badge.img+35
  • Employee
  • 1797 replies
  • June 27, 2022
Your begining and ending tag is wrong. Instead of '<mobiledevices>' and '</mobiledevices>' it needs to be '<mobile_device>' and '</mobile_device>'.
Also, the department you use has to already exist in the Jamf Pro list of Departments (Settings -> Network Organization -> Departments), otherwise you'll get an error.
  • 123 replies
  • June 30, 2022
@Silentgaming if you have time, I suggest you do this.
2 guys from Jamf technical services gave a presentation to a MacAdmins conference a few years ago where they outline how to query the Jamf API's in scripts.  I watched both those videos and learn a TON!  Grab a pot of coffee, some lunch and watch these two videos and they'll help.  All in all, the total time is 2 hours invested in learning how to do this.
First one: https://www.youtube.com/watch?v=GKw0XbHx1GM&t=3459s
Second one: https://www.youtube.com/watch?v=xgSFxUMh7Dg&t=3740s
Cookie policy
Cookie settings
