NetBoot and PXE Boot co-existence
thedanielmatt
New Contributor III
Hey everyone,
I'm trying to sort out setting up NetBoot (NetBoot/SUS Appliance) in a Windows and Cisco environment that is already using PXE booting.
My understanding is the two can co-exist, but will need some help from DHCP. I see a lot of reference to IP Helpers, but mostly in conversations regarding NetBooting across subnets. I also know some people use DHCP Options.
What I haven't been able to sort out is, if I need both and if I need to use DHCP Options, which ones. I know it may not be that simple regarding which options, but it sounds like the IP Helper address is pretty straightforward.
Anyway, hoping someone can share how they've approached/accomplished this.
44 REPLIES 44
calumhunter
Valued Contributor
weird
not sure whats going on there
you'll need to do a docker restart netboot_server after changing permissions
calumhunter
Valued Contributor
You'll also need to do a docker restart netboot_server after changing permissions
scharman
New Contributor
fixed!
the macbook I was trying to netboot had the command bless --netboot bsdp://10.59.195.240 ran on it. and that for some reason wasnt returning the options
calumhunter
Valued Contributor
that'll do it
scharman
New Contributor
Further to this, is there anyway to reset these boot options, as some macs its still not serving a URI some it is.
