NetBoot issues using 10.12.x nbi
a_simmons
Contributor II
Since updating the nbi to 10.12.x I have been unable to NetBoot from different subsets. I'm also only able to NetBoot to up to around 7 devices at a time to Macs on the same subnet.
If I restore the 10.11 NBI it works fine.
I've tried multiple images using autodmg and creating a minimal base image. I've also tried tweaking the settings in autocaspernbi, but I keep getting the same result.
Is anyone else having similar issues with netbooting across subjects with 10.12.x?
4 REPLIES 4
WBS
New Contributor III
I just created mine last week with 10.12.2 and it works fine with different subnets. When i have strange issues like that a reboot of our OSX server normally fixes it.
a_simmons
Contributor II
Thanks William, I'll test it again with 10.12.3 and see how it goes.
a_simmons
Contributor II
What version of the netsus appliance are you using to host the netboot images?
WBS
New Contributor III
I dont use a appliance or i am to tired to understand the question, I use OSX server to host the netboot images.
