Hi Every,
I'm hoping someone may have some ideas on if anything network related could be causing issues with netboot working. I'm setting up a new server at an office that the network isn't setup like our normal offices and I'm suspecting it may be causing issue, but haven't been able to determine why yet. Looking at the logs, I'm not even seeing the server receive a request from the clients.
- The server is setup the exact same as other offices that work fine.
- Server is on the same subnet as the clients.
- Looking at the logs on the server I'm not seeing any mention of a client request or anything for netboot other then logs of it being enabled.
- I also tried adding the netboot onto another system just to make sure it's not an issue with that system.
- I've updated to 10.11.6 since there were some issues with 10.11.4, but that didn't help either.
We also had some issues with our PXE setup working that we had to work around using DHCP option, that makes me suspect the network even more, but still haven't found an option for the netboot side.
Has anyone seem something similar before?
Thanks,
Brandon
