Posted on 03-15-2011 11:21 PM
Anyone out there using NetBoot over http?
I am setting up a Casper Distribution Point for deployment and for security reasons, I can not use NFS protocol for NetBoot.
I have managed to create a NetBoot image for new Thunderbolt MBPs. The size is around 10gb. This works perfectly well with NFS but over http it fails.
I have find this article for 10.3/10.4 and indicates that size matters. Over 2gb image may not work with http...but is it still apply for 10.6+?
http://support.apple.com/kb/TA21349?viewlocale=en_US
I never had to use http protocol for NetBoot images before, so any input will be great.
Cheers
Cem
Posted on 03-16-2011 11:13 AM
OK find it...SSL was enabled and 443 was causing the issue. Now SSL
switched off and port 80 enabled, all works :)
Cem
