Notification management on macOS through JAMF
Asifahmed
New Contributor III
I just wanted to know how I will be able to manage the app notification on macOS through JAMF. Like as SwiftDialog app is installed on my mac but I can see its notification is turned off by default in System Settings/Notification. I want to turn on for SwiftDialog and also its feature has to be managed for both type, banners and alerts, any idea?
1 REPLY 1
Tribruin
Valued Contributor II
You would create a Configuration Profile using the Notifications payload. You use need to know the Bundle ID of the application (looks like Swift Dialog's Bundle ID is au.bartreardon.dialog)
In the profile, you can set whether the notifications are temporary or permanent, as well as whether they can be critical.
