Posted on 11-22-2019 09:12 AM
I've been using the same Office 2016 installer for about a year on 10.13 and 10.14 installations. I just did a clean install on 10.15, ran the Office installer and the volume license serializer and office won't serialize. I have the "activate" option when I launch any program. I checked /Library/Preferences and the plist file that the serializer is supposed to put there will not show up at all. I've tried running the serializer through JAMF and manually ran it on the computer and the file is no where to be found. Is this some sort of permissions issue in 10.15? It's driving me nuts.
Posted on 11-22-2019 09:13 AM
Same.
Posted on 11-22-2019 09:24 AM
I'm convinced it's part of Catalina's new permissions stuff so I dragged the pkg to the Full Disk Access list but that's not fixing it either.
Posted on 11-22-2019 10:37 AM
What versions of O2016? They forked around 16.16 and the old VL wont work.
https://docs.microsoft.com/en-us/officeupdates/update-history-office-for-mac
Posted on 11-22-2019 10:42 AM
16.16
Posted on 11-22-2019 10:46 AM
@dnelson2813 I wonder if you have an old 32-bit version of the VL Serializer there (which of course won't run on Catalina). I posted a 64-bit version to the VLSC in the summer of last year, so you may need to go download the newer version.
Posted on 11-22-2019 11:16 AM
@pbowden I think you must be right. Catalina isn't giving me any sort of warnings, but I downloaded this serializer a while ago so it probably is 32 bit. I don't have our VLSC login info so I'll have to try this when I can get into the site. Thanks for the help.
Posted on 11-22-2019 11:58 AM
@dnelson2813 no problems. If you need help today, send me an email (pbowden@microsoft.com) and I can get you the VL Serializer download to confirm that this is indeed the issue.
Posted on 11-22-2019 12:45 PM
It turns out I did have the 32 bit installer. Thanks for the help @pbowden
