When using Jamf Imaging to push a configuration down to a computer, we are seeing that across different models that it is acting like everything is working but the computers are not being configured. The process that we use is to boot to a USB drive with a small os image on it that contains the JAMF imaging application. Select the configuration we want and target the Macintosh HD. However in looking at the CasperImagingDebug.log it appears that the majority of our installers can't locate /Volumes/Macintosh HD. The only one that worked in the log below was Google Chrome, all the others failed to see the drive. This process has worked in the past and works on our test VMs but it is not working in our production process. Any help is appreciated as we are at a loss and my GoogleFu is failing me on this one. Below is the log
6/15/18 9:56:27 AM -
partitionAndOrFormatAndInstallPackagesToMainPartition - Started
partitionAndOrFormatAndInstallPackagesToMainPartition - configuration was selected: Set up new Miami Notebook
partitionAndOrFormatAndInstallPackagesToMainPartition - erase target drive not selected
Event logged: Installing Package...
Installing Cisco AnyConnect-4.4.03034.pkg...
Executing Async Command (From ParamArray):
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'Cisco AnyConnect-4.4.03034.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 9:58:11 AM -
Result of Install:
Copying Cisco AnyConnect-4.4.03034.pkg...
<progress status="Installing Cisco AnyConnect-4.4.03034.pkg...">
installer: Error trying to locate volume at /Volumes/Macintosh HD
<exitCode>1</exitCode>
</progress>
Installation failed. The installer reported: installer: Error trying to locate volume at /Volumes/Macintosh HD
Installing ClamXav 2.7.5...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'ClamXav 2.7.5.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 9:59:56 AM -
Result of Install:
Copying ClamXav 2.7.5.pkg...
Installing ClamXav 2.7.5.pkg...
<progress status="Installing ClamXav 2.7.5.pkg...">
</progress>
Installing Dropbox 2.0.pkg...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'Dropbox 2.0.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:01:33 AM -
Result of Install:
Copying Dropbox 2.0.pkg...
<progress status="Installing Dropbox 2.0.pkg...">
</progress>
Installing Google Chrome-63.0.3239.132.dmg...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'Google Chrome 63.0.3239.132.dmg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:01:43 AM -
Result of Install:
Installing Google Chrome 63.0.3239.132.dmg...
Closing package...
Installing Microsoft Office 2016 O365-16.9.18011602.pkg...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'Microsoft Office 2016 16.9.18011602.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:04:36 AM -
Result of Install:
Copying Microsoft Office 2016 16.9.18011602.pkg...
Installing Microsoft Office 2016 16.9.18011602.pkg...
<progress status="Installing Microsoft Office 2016 16.9.18011602.pkg...">
</progress>
Installing NoMAD_Student.pkg...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'NoMAD_Student.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:06:13 AM -
Result of Install:
Copying NoMAD_Student.pkg...
<progress status="Installing NoMAD_Student.pkg...">
</progress>
Installing Read Write Gold 6.0.6...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'RWG 6.0.6.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:08:19 AM -
Result of Install:
Copying RWG 6.0.6.pkg...
Installing RWG 6.0.6.pkg...
<progress status="Installing RWG 6.0.6.pkg...">
</progress>
Installing uPrint.pkg...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'install' '-package' 'uPrint.pkg' '-target' '/Volumes/Macintosh HD' '-path' '/Volumes/JSS_Share$/Packages/' '-showProgress' '' '' '-httpAuthMethod' '' '-httpUsername' '' '-httpPasshash' '%c4%c5%c4%cf'
6/15/18 10:10:04 AM -
Result of Install:
Copying uPrint.pkg...
<progress status="Installing uPrint.pkg...">
</progress>
Executing Async Command (From Array):
'/usr/sbin/vsdbutil' '-a' '/Volumes/Macintosh HD'
6/15/18 10:10:04 AM - Command Result:
Event logged: Creating /private/etc/jamf.conf...
'/Applications/Jamf Imaging.app/Contents/Support/jamf' 'createConf' '-target' '/Volumes/Macintosh HD' '-url' 'https://applemanage.miamioh.edu:8443' '-verifySSLCert' 'always'
6/15/18 10:10:07 AM -
Command Result:
Creating configuration file for https://applemanage.miamioh.edu:8443/...
The SSL Certificate for https://applemanage.miamioh.edu:8443/ must be trusted for the jamf binary to connect to it.
