Packages Distribution Point Settings for Policies
boleary
New Contributor
For those of you using Jamf Cloud instances, I'm curious if you've ever run into issues with policies downloading large ( > 5GB) files when using the "Each computer's default" distribution point rather than the "Cloud" distribution point. I have one policy using "default" for a .pkg file over 12GB that works fine, but another with a 8.25GB .pkg file that kept failing until I switched it to "cloud distribution". The error message was "Error: The package is not found on the server" even after re-uploading the file.
For our Jamf Pro instance, we have no File Share Distribution Points, and use AWS for our Cloud Distribution Point. We have the "Use as principal distribution point" check box ticked for the Cloud distro, so my understanding it that is shouldn't matter whether the distribution point option in a policy is set to "default" or "Cloud" because either one should still be pulling from AWS. But for some reason as yet unknown to me, it does make a difference for second policy above with the 8.25GB file.
So should we change all our policies to specifically designate the Cloud distribution point from now on?
2 REPLIES 2
CapU
Contributor III
We moved to the cloud last year. I elected to maintain both an on-prem file server and cloud server. Depending on the app, I just select the appropriate  distribution type. I maintain GarageBand in our environment. On prem makes sense for this app
boleary
New Contributor
We aren't using an on-prem file server. So my understanding is that the "default" distro point should point to the cloud.
